Home › Forums › General discussions › Wurlitzer 5220 : comment passer en free-play ?
- This topic has 34 replies, 4 voices, and was last updated 5 years, 1 month ago by
4 October 2019 at 1 h 14 min #46632
mic
ParticipantBonjour,
Je suis en possession d’une Wallbox Wurlitzer 5220A . J’ai installé ma carte wallbox2mp3, mais malheureusement malgré mes très nombreuses recherches je n’arrive pas à trouver comment passer en crédit gratuit sur cette machine pour pouvoir profiter de ma musique.
Pourriez vous m’indiquer la marche à suivre ?
Merci d’avance
Mic.
This topic was modified 5 years, 6 months ago by
4 October 2019 at 21 h 06 min #46633
ParticipantBonjour Mic
Unfortunately my French is very poor, so you will have to translate this.
I have had no experience with the 5220 wallbox, & this is purely a guess.
On the 5210 &5250 the credit units are situated in the lower right corner and are predominantly a mechanical system that operates a small electrical switch.
The credit unit either opens or closes the contacts of the switch when there are credits available. To give free plays the switch could be bypassed so the action of the credit unit has no affect on the switch. As I said this is purely based on my guess that Wurliter carried on using a similar credit system on the 5220.
Do you have a Manual for the 5220?
Unfortunately there isn’t one on the Support section of this site.
8 October 2019 at 0 h 14 min #46642
KeymasterManuel en ligne dans SUPPORT.
Thanks to Paul North.
8 October 2019 at 8 h 24 min #46643
ParticipantHi MIC
Since posting my first reply to your question I have been able to source a manual for the 5220, which has now been added to the support section here on this site.
After looking at the manual it is obvious to me that I had assumed incorrectly & that the credit unit is not the same as a 5250, however it would appear that if you were to to fit a simple switch across the Key switch that is shown in the manual, & is labelled on the photos of the play rack. Wurlitzer call the credit unit a play rack.
9 October 2019 at 20 h 40 min #46649
mic
ParticipantThanks a lot for your help. The documents will be of great help.
Mic
10 October 2019 at 3 h 15 min #46651
KeymasterIl faudrait faire une photo du “playrak”, mais visiblement, il y a une roue crantée qui sert à décrémenter les crédits.
Il doit donc y avoir un “doigt” qui pousse la roue pour enlever le crédit. C’est ce mécanisme qu’il faut bloquer, démonter, couper… suivant comment c’est fait.
This reply was modified 5 years, 6 months ago by
10 October 2019 at 8 h 17 min #46653
ParticipantHope the Manual helps. Let us know how you get on.
22 October 2019 at 22 h 31 min #46661
KeymasterIf you succeed to convert it to free-play take some photos and let us know.
Could be useful to others.
Thanks
14 March 2020 at 10 h 37 min #46977
Guillaume
ParticipantHello to all,
i have the same problem with my own Wurlitzer 5220, did you fix the problem (free play configuration)? If yes could you send me some pictures and information to explain how to do it ?
many thanks !
Guillaume
14 March 2020 at 12 h 19 min #46978
ParticipantHi Guillaume
Welcome to the forum,
what is the problem that you have?
what exactly are you trying to achieve ?
have you looked at the manual for the 5220?
14 March 2020 at 12 h 56 min #46979
Guillaume
ParticipantDear Scudie,
many thanks for your message, in fact the situation is the following : I have installed a wallbox2mp3 into my Wurlitzer 5220 , the cabling seems ok , and there is no error message (no flash red LED) everything seems ok also with the SDCard.
I have removed the cash system and put a bridge on the J101 as indicated in some forum , but I am not really sure that my bridge is fine ( 2nd row and between 2&3)..
when I make a selection, the wheel turn (only 1 full turn)) and stop exactly at the same place , and no music run ( no signal on the wallbox2mp3)
So my concern is about the wallbox and not necessary the wallbox2mp3 (for the moment..) and I would like know if my free play bridge is fine, and if there is other thing to check on the wallbox ( wheel system, cabling ,….)
many thanks for your help !
kind regards
Guillaume -
14 March 2020 at 15 h 09 min #46980
ParticipantHello Guillaum
As I mentioned in a previous post I do not own a 5220 or 5225 so I have no experience with them, but I will try my best to help you as much as I can.
This bridge you have installed on J101, what is J101? Is there any pictures of this in the manual.
You say 2nd row between 2& 3 please explain 2nd row of what ?
14 March 2020 at 19 h 01 min #46981
Guillaume
ParticipantHerewith a picture of the bridge :
As you can see there are 4 rows on the j101 the bridge is between the 2 nd and 3rd position on the 2nd row.i have seen in some forum that bridge position would permit to by pass the credit system.
14 March 2020 at 19 h 03 min #46982
KeymasterNo photo
14 March 2020 at 19 h 04 min #46983
Guillaume
14 March 2020 at 19 h 06 min #46984
Guillaume
14 March 2020 at 19 h 07 min #46985
Guillaume
ParticipantSorry some issue to attached the pictures…
14 March 2020 at 19 h 32 min #46986
KeymasterDon’t have a 5220, but your bridge is done the way it is pointed in a french forum.
Did you clean all contacts in the wallbox ?
You get the right voltage out of the transformer ? -
14 March 2020 at 19 h 52 min #46987
Guillaume
Participantthanks for your message,
regarding the voltage I checked and I have a little bit more than 24vAC out of the transformer.
the contacts have been cleaned but maybe there are some contacts that I have forgotten. I will check again.
that is strange is about the selection wheel which turn And stop systematically at the same place . I thought that the wheel should stop according the selection…
This reply was modified 5 years, 1 month ago by
14 March 2020 at 21 h 04 min #46988
KeymasterHave you adjusted “Selector Switch Latch” as per instructions manual on page 6 ?
http://www.wallbox2mp3.com/wp-content/uploads/2019/10/W-5220-Service-Manual.pdf
Latch will make a full turn for each selection.
14 March 2020 at 23 h 05 min #46991
Guillaume
ParticipantI have done the test and both buttons are release as indicated in the adjustment section page 5
After that when I turn on the wallbox the wheel turn automatically to the initial position
but It still doesn’t work..
15 March 2020 at 11 h 25 min #46992
ParticipantHi
So J101 is the connection socket for the credit unit plug, what I understand to be called the playrack in the manual.
The selector wheel on all the makes & models I have worked on so far have made one complete revolution once the selection button/ buttons are pressed.
So if you were to manually advance your selector wheel to its no credit position with the power off, then turn the power on nothing should happen to the selector wheel untill you put the bridge in to J101 at this point the selector wheel should advance a little to the credit position at which point the selection button can be pressed and they should latch after the second button is pressed the selector wheel should make one complete revolution returning to the same position as it started from before the selection was made, ie the credit position.
If you were to remove the bridge at this point then make a selection the wheel would advance but stop short of its starting point, it would now be in its home position ie no credits.
15 March 2020 at 11 h 42 min #46993
ParticipantDo you have 24volt bulb?
You can check the signal pulses with a 24v bulb and some wire, connect one side of the bulb to the 25vac terminal and the other side of the bulb to the signal connection.
Make a selection as the wheel revolves the bulb should flash as it passes over the contacts. Or if you have a test meter with an audible continuity option you could connect one probe to chassis / ground and the other to signal.
with the power off & the selection buttons pressed, if you advance the selector wheel manually you should get a audible signal as it travels over contacts.
15 March 2020 at 12 h 38 min #46994
Guillaume
ParticipantHello Scudie,
i have tested the signal with a test meter, something happens !
When I put the probes as indicated on the below picture , after the wheel revolution the music run!
Due to this fact I don’t if my cabling is correct…
15 March 2020 at 17 h 08 min #46995
KeymasterAccording to manual
24v is terminal 3
Ground / COMMON is terminal G
Pulse/SIGNAL is terminal 1ok ?
15 March 2020 at 17 h 25 min #46997
Guillaume
ParticipantYes that is correct from my side, same cabling.
15 March 2020 at 18 h 07 min #46998
KeymasterProbes are on 1 and G ?
15 March 2020 at 18 h 21 min #46999
Guillaume
15 March 2020 at 18 h 35 min #47002
KeymasterEn suivant le signal, j’arrive a des switches.
Peut-être regarder ça, nettoyage des contacts…Je peux aussi me tromper.
15 March 2020 at 19 h 09 min #47003
Guillaume
ParticipantHello to all!
great news I fix my problem it was a contact which was not good.
My wallbox is now working well !
many thanks to all of you for your help and support !have a nice evening
guillaume
15 March 2020 at 19 h 27 min #47005
KeymasterSi ça fonctionne, c’est le principal, mais niveau soudure, si ce sont les tiennes…
Je te conseille amicalement de t’entraîner en suivant un tuto sur youtube si besoin.
Car comme tu l’as compris, mauvaise soudure = problème.
Et ça ressemble a des soudures sèches, qui dans le temps créeront des problèmes.
15 March 2020 at 19 h 28 min #47006
KeymasterC’est la carte de quoi en cause ?
Which card was faulty ?
15 March 2020 at 21 h 38 min #47007
Guillaume
ParticipantIl s’agit bien d’une réparation de fortune , pas de quoi en effet à être très fier , je vais reprendre tout cela.
Il s’agit d’une carte qui fait le lien entre le bornier de connexion et la roue de sélection elle se situe sur le système de sélection. J’ai simplement suivi le fil du signal en partant du bornier.après avoir réalisé plusieurs essais, j’ai en effet solutionné une partie du pb , la sélection permet de lancer un morceau mais pas le bon si je me rapporte aux étiquettes issues du logiciel wallbox2mp3…
une idée ?
merci et bonne soirée
guillaume
16 March 2020 at 8 h 32 min #47008
i don’t speak French so had to translate, would help me if you posted in English.
If I understand correctly your wallbox had a fault on the signal circuit that you have now fixed and it now plays a selection when selection buttons are pressed?
But it is not playing the correct music ?
when you select A1 is it correct?
if not does it always play the same song if A1 is selected several times?
Does it play any music if any of the V selections are made ie V1 or V2 or V3?
