Volume control pot
Home Forums Wallbox2mp3 installation Volume control pot
Viewing 4 reply threads
    • #48112
      doogle
      Hi all,
      I’ve  got my sc1 up and running but having problem with the volume control if I put it up to the higher end it interferes with the the playing (blanks out) it only seems to work when in the lower end even then it happens now and again and it’s to low for me, has anyone had this problem it’s the 1.5 version, Thanks doogle
    • #48120
      Does the same happen with headphones ?
      Did you connect speakers direct to wallbox2mp3 card ?
      Regarding DIP switch, Did you try position 2 on or off ?
      Do you use on board pot with or without external connected ?
    • #48125
      doogle
      Hi Klaatu,
      Yes speakers wired from emulator direct to wallbox, I put headphones in and it doesn’t happen but the sound is very very low until the top end of the controller, also the wallbox speakers are still on, don’t know if they should be off with headphones plugged in but as soon as earphones removed problem is back, yes tried remote to
    • #48126
      and with remote, you change the dip switch 2 ?
    • #48127
      doogle
      Yes switch in position 2
  • The topic ‘Volume control pot’ is closed to new replies.
