Home › Forums › General discussions › [SOLVED] Title strips
- This topic has 7 replies, 4 voices, and was last updated 4 years, 10 months ago by
stingman.
1 February 2020 at 16 h 53 min #46937
thatsmesd
ParticipantJust changed some of my songs and went to print the title strips using the provided software, for some reason when I click to automatically retrieve songs and select a folder it just lists the first song or whichever individual song I select, I cant get it to list all the songs in the folder, It worked fine several times before and even listed all the songs from the renamed mp3’s on the sd card.
I re downloaded the software but no joy, am I having a senior moment or is there an issue with the software? running windows 10, Any help would be appreciated. -
1 February 2020 at 17 h 26 min #46938
ParticipantI use Windows 10 and have never had that problem. Maybe a problem with your new input file. Did you keep a copy of the old file? Does it still work?
1 February 2020 at 20 h 33 min #46939
ParticipantI also use Windows 10 with no problems, did a new SD for one of my box’s this week.
All worked fine for me, are you sure you have all the tracks in the folder?
2 February 2020 at 15 h 26 min #46940
thatsmesd
ParticipantTried again today, I open the application, select the wallbox type, click continue to playlist, click the “Choice Folder” button, select the folder with 16 mp3 files in it then click open, it then just shows the selected folder & first song title in the top right hand box where is said “select MP3 file”, nothing showing in any of the title or artist boxes, I thought it should list all the tagged mp3 files on the folder I selected?
Am I doing something wrong? -
2 February 2020 at 15 h 35 min #46941
ParticipantSounds like a problem with your file. Did you have one that worked previously?
2 February 2020 at 16 h 03 min #46942
thatsmesd
ParticipantSorted, tried it on my laptop and it worked ok, re installed Java on my PC and it works ok now.
2 February 2020 at 17 h 47 min #46943
ParticipantNice one glad to here that you got sorted, very peculiar as it had obviously worked befor.
Things seem to disappear on my phone!
20 May 2020 at 15 h 51 min #47294
stingman
I am having the exact same problem when attempting to program a new SD card from a file source that I used last year to successfully populate a 1GB card.
When I choose the file source using the wallbox2mp3 software, only one title downloads from the file with 200 MP3s. I reloaded the latest version of JAVA software with the same results. I tried both V 1.4 and V1.5.
I had no problem in the past programming SD cards.
