The case for Making selections by Bluetooth
Home Forums Suggestions The case for Making selections by Bluetooth
Viewing 0 reply threads
    • #46735
      RichDon
      It has been mentioned that a Bluetooth app may be developed for the new hardware and that making selections by Bluetooth would not make sense given that this is a wallbox converter and you can play songs through Bluetooth using a music app. But there could be an expanded market if  selections could be made through the app. A system could be set up without a wallbox or before a wallbox was added. It means that you could make and play selections without the phone being continually connected which would be more convenient. Also you would not have the additional coding and decoding required by Bluetooth which would provide higher fidelity through better resolution. Even if the interface were as simple as allowing a letter and number selection to be entered it could be quite a convenience.
      • This topic was modified 5 years, 4 months ago by RichDon. Reason: Typo
