Home › Forums › Wallbox2mp3 installation › Seeburg SC2 freeplay freekredit ?
- This topic has 8 replies, 3 voices, and was last updated 4 years, 8 months ago by
13 July 2020 at 23 h 56 min #47531
oskar
ParticipantHello
I ask for help
i have a seeburg sc2 remote selector
how do i make free credit or free play?
I have read and can no longer find the page.
it said.
Connect 3 cables together at the coin validator and then connect with 24vac with 10ohm resistance.
can that be correct?
14 July 2020 at 22 h 49 min #47532
ParticipantHi Oskar
What you have described in your post is if you wish to use the SC2 as a stand alone unit & want to use coins.
Is the credit unit fitted inside your consolette?
It should be situated adjacent to the right hand speaker and has a 12 pin plug connector that pushes into a 12 pin socket.
If the credit unit is missing, as you look at the socket front if the top left is #1 & bottom right is #12 , bridge terminal 1 on the socket(top left) to terminal 7 , 3rd row down, left & that will give you freeplay.
14 July 2020 at 23 h 01 min #47533
ParticipantHi Oskar
If the credit unit is present there is a description of how to achieve free play in the Tutorials section The post is called how to achieve freeplay on a SC1 and Rockola 507.
14 July 2020 at 23 h 09 min #47534
oskar
ParticipantHello
many many thanks for the answer.
i write this message with google translate.
I only have remote control SC2.
I don’t have a seeburg jukebox.
I want to operate the SC2 remote selector on my own.
I would like to connect a wallbox2mp3 device to my SC2 remote selector.
I don’t know if I have this credit unit in my remote dialer. I can check tomorrow.
I will do it step by step.
first get this wallbox2mp3 device.
then connect to my remote dialer.
I am currently painting the casing.I will remember your answer.
many thanks
if I have any questions, I hope you can help me again.
17 July 2020 at 11 h 37 min #47542
oskar
ParticipantHello
i want to run my sc2 alone.
without juelbox.
how do i play free spins?
my sc1 has the connector behind the right speaker.
it has 12 points.should I pull out the plug and then connect it to the jacks Punkt1 and Punkt 7?
do I have such a free spin?
is this free spin then permanent? or just once?
18 July 2020 at 10 h 46 min #47543
ParticipantHi Oskar
If you have the credit unit the easiest way to achieve free play is to do as the post suggests in the tutorial section.
Free play will then be achieved until some one changes the modification.
You don’t require a jukebox if you are using a wallbox2mp3 unit.
Have you got a 25VAC transformer to power the SC 1 ?
18 July 2020 at 15 h 38 min #47544
oskar
ParticipantHello
I ordered a wallbox2mp3.
comes in 10 days.yes i have a power supply for power supply.
output 24v 4A ACi tried the power supply yesterday.
I connected it to the SC1.I have a coin validator in my sc1.
it is connected behind the right speaker.
it has 12 points.
…I connected and tried the power supply yesterday.
I chose letter A and then the 4th
then starts turning.
then button 4 comes out.
but then the button A remains in it.then I cleaned the contacts on the wheel.
then I voted again.
A 4
the wheel turns and then button 4 comes out and button A has trouble getting out.
then I helped.
then the button A comes out.i think it is without fat.
it has to be cleaned and greased.so I think it works.
I wait until the wallbox2mp3 comes, then I test again.
I didn’t throw a coin in.
the 12 point plug is in it.
where exactly is this info in turtorial?
can you copy that to me? in here.
Thank you for your help
19 July 2020 at 16 h 32 min #47546
ParticipantHi Oskar
when you click on the Forum it opens a list of 5 titles Wallbox2mp3 installations at the top & General Discussions at the bottom.
Tutorials is halfway down the list.
20 July 2020 at 16 h 03 min #47547
KeymasterHere you go for Free play http://www.wallbox2mp3.com/forums/topic/seeburg-sc1-consolette/
