- This topic has 11 replies, 3 voices, and was last updated 6 years, 1 month ago by
2 February 2019 at 17 h 29 min #44018
irus18352
ParticipantHi,
I have two Seeburg SC1s and I’d like to convert them. I’ve applied 24v ac to them and they both have the same problem. Although the revolving selector works it has to be pushed to the contact point and likewise helped to its rest point. The coin mechs have been removed, is there something I need to do? -
2 February 2019 at 20 h 03 min #44019
KeymasterHello Irus18352,
Did you clean all contacts on the wheels and latches everywhere in the consolette ?
Did you put it in Free play ?
Have you check distance on APU10 : see page 9 of manual http://jukeboxwiz.com/uploads/Seeburg_SC1.pdf
2 February 2019 at 22 h 23 min #44020
irus18352
ParticipantHi, how do I put it into ‘freeplay’?
3 February 2019 at 22 h 33 min #44021
Keymaster -
4 February 2019 at 23 h 14 min #44022
ParticipantIf you have not sorted the problem yet it may be worth checking the gaps of the contacts on the latch bar setting switch, its below the contact disc, it should have a protective plate covering it, the plate is sometimes missing so the contacts get damaged/ bent.
4 February 2019 at 23 h 15 min #44023
KeymasterFor free play : you need to locate the Grey (SC) or White/Black (SCH) wire on top of the APU,
and short it to Ground. -
5 February 2019 at 15 h 58 min #44029
irus18352
ParticipantThanks everyone, that solved it Klaatu.
Do you know how to put a Rockola 507 into freeplay too?🙂
5 February 2019 at 23 h 24 min #44030
ParticipantHi
I have not had any experience with Rockola 507 or 506 , but I am guessing that free play could be achieved in one of two ways firstly you could fit a momentary switch that replicates a coin being inserted this would register a credit so would put the wiper arm of the contact disc into a credit position, this button would have to be pressed before each selection, or secondly if credit is registered on the credit unit & if the credit unit was then doctored so that it could not remove the credit as the selection is made, it would stay in credit giving free plays.
Not sure how much help it would be but there is a wiring diagram for the 507 in the Support section at the top of the page.
Cheers
15 February 2019 at 12 h 58 min #44232
irus18352
ParticipantThanks Klaatu and Scudie, 🙂
16 February 2019 at 17 h 57 min #44301
KeymasterHi irus18352,
Show us your wallbox 😉
Did you manage to put in free play the Rockola 507 ?
17 February 2019 at 15 h 43 min #44409
KeymasterHello irus18352, maybe best to continue on a dedicated facebook group, too much spam here… https://www.facebook.com/groups/Jukebox.Wallbox.Consolette.Convert.2mp3/
