Home › Forums › Wallbox2mp3 installation › ROWE AMI WALL BOX WRD-200
- This topic has 12 replies, 3 voices, and was last updated 4 years, 4 months ago by
13 November 2020 at 8 h 41 min #47914
chris65
ParticipantBonjour
je viens de récupérer une ROWE AMI WALL BOX WRD-200.
Je recherche la doc technique de cette wallbox.
Une aide pour la connectique (0.. 24V, signal , etc..)
merci
christophe
13 November 2020 at 21 h 15 min #47916
ParticipantHi Christophe
If you are contemplating connecting a Rowe Ami WRD 200 to a wallbox2mp3 adapter it may be an idea to email Fabien or Gaëlle for advice on the compatibility of a Rowe Ami WRD 200 with a wallbox2mp3 unit, as far as I can see the WRD is not currently on the list of compatible wallbox’s although there is a photo of one adjacent to the list which is a little confusing.
There is a manual for the WRA WRB & WRC in the Support section, I think the WRD was there first wallbox that was solid state so the manual for the others may be of no use to you with the WRD.
Sorry I can’t be of any further help with the manual.
13 November 2020 at 21 h 46 min #47917
chris65
ParticipantHello Scudie
thanks for these informations, The WRD is an solid state. I will ask Gaelle to know for interfacing with Wallbox2MP3.
For know , I just need some schematic to understand how I can connect the power supply, to put power ON first.
I was looking on internet , and I don’t find any manual to buy on WRD 200
Regards
Christophe.
13 November 2020 at 21 h 57 min #47918
Perhaps if you could post a photo of the inside of the WRD showing the connector strip someone may be able to identify them?
13 November 2020 at 22 h 36 min #47919
ParticipantThere is a WRD manual on the US Ebay site. But like Scudie I don’t think there is a currently available adapter. The CDadapter folks have an emulator for the E &F models but the solid state boxes can be expensive to emulate. Powering it up should not be a problem though show us the pictures.
14 November 2020 at 15 h 57 min #47923
chris65
ParticipantOk ,thank, I found the schematic on US Ebay.
See the connector picture.
Regards.
Christophe.
14 November 2020 at 15 h 57 min #47922
chris65
ParticipantHi Randy
thanks , I will look for on ebay site.
See attached the picture of the connector for the wallbox.
Regards.
Christophe
14 November 2020 at 15 h 57 min #47921
ParticipantAlso, I have a solid state ROWE – the CD WB. Perhaps the connector strip in that is similar to yours. The top terminal is labeled AC Power and the second terminal is AC Common. It is a 24v transformer.
14 November 2020 at 16 h 15 min #47928
ParticipantOK so yours is basically the same with power and ground/common on the top two terminals. On your strip common is the top terminal and power is the second. I bought a Ring Doorbell transformer from Amazon to power mine, I think the French Amazon site has them as well. Really any 24v AC transformer will work.
14 November 2020 at 18 h 14 min #47929
ParticipantGood Aternoon Guys
From Memory that connector strip looks to be different to the WRA that I converted & have the manual for. Glad that Randy was able to help although the label should be fairly self explanatory.
On the subject of transformers I use a 25Vac terroidal tranformer from RS electronics, they do appear to have a French website.
The part number is 671-8956
I Don’t know how they compare in price to stuff for sale on Ebay might be worth taking a look.
14 November 2020 at 18 h 15 min #47930
chris65
ParticipantOK Randy, thanks, I connected an 24 AC power as your mentionned and the wallbox is running.
Now I just have to analyse the signal on Data line and clock line to see when I do a disk selection ,
if it is compatible with wallbox2MP3, I will ask Gaelle.
14 November 2020 at 20 h 33 min #47935
ParticipantGood to see you have it powered up, will be interesting to see what you are able to do with it, keep us informed.
14 November 2020 at 20 h 35 min #47936
ParticipantGood looking wallbox, I hope you get it working. It does not appear to be much different than the Seeburg DEC, maybe Fabien can adapt that emulator for this box.
