Which Power cord ? Home › Forums › General discussions › Which Power cord ? Tagged: Power cord This topic has 5 replies, 4 voices, and was last updated 5 years, 3 months ago by Scudie. Viewing 5 reply threads Author Posts 7 January 2020 at 9 h 58 min #46843 jwd1115Participant Probably a real stupid question but for a seeburg 3w1, what voltage and amp power cord do you prescribe to connect to the terminals/transformer? This topic was modified 5 years, 3 months ago by Klaatu. 7 January 2020 at 15 h 52 min #46844 SoonerParticipant I use a standard lamp cord: https://www.ebay.com/p/7008911664?iid=163681903193 I also put a 1 amp fuse in front of the transformer (although 1/2 amp would probably be better). 7 January 2020 at 20 h 13 min #46846 ScudieParticipant I use 3 core 1.5 mm2 round flex, with a 3amp fuse in the three pin plug and the earth wire connected to the wallbox chassis. I fit an automotive 3amp blade fuse on the output of the transformer. Cheers Scudie 7 January 2020 at 23 h 10 min #46847 thatsmesdParticipant I thought the 24v “Com” was connected to the chassis? 8 January 2020 at 3 h 07 min #46848 SoonerParticipant Yes the chassis is connected to the 24V “common”. Interesting to know the chassis can also be grounded. I may need to retro-fit some of mine to be safe. 8 January 2020 at 8 h 26 min #46849 ScudieParticipant I also use the the chassis as a ground for 5v dc for LED in the illumination of the pages. Author Posts Viewing 5 reply threads You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Enter Captcha Here : * Log In
