Packard wallbox
Home Forums General discussions Packard wallbox
Viewing 1 reply thread
    • #419
      seancalla
      Hi
      I was thinking of ordering one of the pla mor packard units. From the pdf document its pretty hard to see where the coin and free credit wires are going to, is this explained a bit more in the instructions. Also its hard to distinguish from the photo where the ground(-5volt) wire is going to. Also you mention about stripping the unit of any wiring. Does this include existing coin wiring to the comparitor. And do you supply the bulb for the lighting of what type of bulb would be used. The documents for the ami and seeburg explain it very well and are easy to follow but for the packard its more difficult to follow
      regards
      Sean
    • #44034
      Everything is well explained in the pdf about wiring, no difficulty for me.
      There is no free credit, you need to use coin or make a rod pushing the latch for coin.
      LED bulbs are included, but best to use original, as the led aren’t pointing correctly for a 180 diffusion.
      Did you buy a wallbox2mp3 card since that time ?
