Home › Forums › Wallbox2mp3 installation › Packard MP3 not working correctly
- This topic has 4 replies, 3 voices, and was last updated 4 years, 3 months ago by
simong_uk.
25 June 2020 at 2 h 24 min #47509
gemmy
Participant<p style=”text-align: left;”>I wonder if anyone could help me, I’m having problems with the wallbox2mp3 made for the Packard. I have checked everything a million times from the resistors, the wiring, the songs, buying a new SD card, using my other Packard Wallbox and still it’s not working 100%. 10 out of the 24 songs don’t pick the right one…</p>
1 is playing 2 ❌
2 is playing 3 ❌
3 is playing 4 ❌
4 is playing 5 ❌
5 is playing 6❌
6 is playing 7❌
7 is playing 8 ❌
8 is playing 9❌
9 is playing 9 ✔️
10 is playing 10✔️
11 is playing 11✔️
12 is playing 12✔️
13 is playing 13✔️
14 is playing 14✔️
15 is playing 15 ✔️
16 is playing 16✔️
17 is playing 17✔️
18 is playing 18 ✔️
19 is playing 19✔️
20 is playing 20 ✔️
21 is playing 21✔️
22 is playing 22✔️
23 is playing 22❌
24 is playing 23 ❌ -
25 June 2020 at 3 h 50 min #47510
ParticipantSo you have measured the resistance at each selection and it changes .2-.3 volts progressively?
Also, the coin micro switch on these can be problematic, have you tried bypassing the switch?
Or testing the voltage output at the switch to ensure it also shows the progression of the .2-.3 volts for each selection.
You can try wiring in a momentary switch to replicate the signal from the coin switch, they can provide a more consistent contact to allow the proper voltage to pass.
When you say you used another wallbox – you have two and they produce exactly the same result?
25 June 2020 at 3 h 59 min #47511
ParticipantI can’t edit my first post but pictures of your wiring and switch mechanism would help there are a few different versions of this wallbox.
28 June 2020 at 6 h 47 min #47523
ParticipantCan’t really help you if you won’t communicate. There is generally no easy solution if you have followed the Retroelonik instructions correctly, but you have not made that clear. From your description I would guess that there is an incorrect voltage pulse from contact one to contact eight and 23 to 24. If you can provide those voltage readings, and they are correct then you may have a bad PCB and the folks at WB2MP3 will send you a new one as they have done for me in the past. The easiest way to do that is to put your test leads at the signal and negative posts on the PCB and record the voltage at each selection, if they start at about .2 volts and progress at .2 to .3 volts at each selection and don’t provide the right song you may have a bad board. I’ve done a couple of these and found the most probable point of failure is the coin micro-switch, it often does not provide enough contact to signal the right voltage reading to the PCB. One solution might be to install a momentary switch to provide enough contact interval to let the voltage pulse to pass to the PCB . Hope you get it worked out.
16 December 2020 at 9 h 41 min #48135
simong_uk
Participant@ Gemmy – Did you ever solve this problem as I have exactly the same issue with my unit ?
