[SOLVED] 'Not any SD Card Found'
Home › Forums › Wallbox2mp3 installation › [SOLVED] 'Not any SD Card Found'
Viewing 2 reply threads
    • #425
      Rob18244
      Hello everyone,
      I’m currently trying to build a playlist but I am receiving an error advising;
      ‘Not any SD Card Found, you need to connect a blank SD Card formatted in either Fat16 or Fat32’.
      I have connected an SD card to my PC. The SD Card is blank, formatted in FAT32 and I can access it directly from the PC, but the software does not appear to be able to see it.
      Any advice?
      Thanks,
      Rob
    • #426
      Hi Rob
      Are you trying to build your play list manually ?
      I used the software to import all the files in one go from a single folder, & have not tried to do it manually.
      Doing it with the software is fairly easy even for me.
      My only gripe would be if you were wanting to have the A side & B side both of the same artist ie like on a record,it is a slow and tedious job moving them about once they have been imported into the software.
      Cheers
      Paul
    • #43933
      fabienw
      Hello Rob and sorry for the huge delay of my response,
      you’re certainly using Linux ,if so,it was a bug and it has been fixed concerning Linux and Macos with the last release ; indeed Linux and Macos manage SDcards a different way. Now the software detects the OS and search for the SDcard according to this information.
