Home › Forums › Wallbox2mp3 installation › Low Volume Output from v1.5 Mini Jack
- This topic has 9 replies, 1 voice, and was last updated 4 years, 7 months ago by
artsound.
11 June 2020 at 15 h 22 min #47472
pinbill
ParticipantI am having a problem with a recently received v1.5 unit which may or may not be specific to my particular unit or may be an issue with this version.
Currently I am only using the audio output from the unamplified mini jack on the v1.5. It appears that the volume output level from that jack is much lower than the typical line level output from, for example, an iPhone or other MP3 player. This has resulted in my not being able to obtain reasonable wallbox2mp3 volume levels from any of my self-powered speakers, even at their max volume levels. More problematic, I am trying to use a Bluetooth transmitter/receiver from the wallbox2mp3’s line out but the level of output from the mini jack does not seem strong enough for a meaningful signal out of the Bluetooth receiver (into my Sonos system). The Bluetooth transmitter/receiver works fine when using other sources such as my iPhone output.
Is it possible that my unit is defective, or is this expected behavior? Any input or suggestions would be appreciated.
11 June 2020 at 20 h 32 min #47474
ParticipantGood evening Pinbill
Are you using the onboard volume pot or the remote one ?
How are the set the positions of the 3 switches on the board set ?
12 June 2020 at 1 h 34 min #47475
pinbill
ParticipantThe dips were set as follows:
1: off, 2: on, 3: on
With these settings, the volume out of the jack was hardly audible and the volume pot made no changes.
HOWEVER, after reading your post I changed dip 3 to off and voila — I could hear audio out of the mini jack with the volume knob turned fully up! Not very loud but definitely now audible with IEMs.
I don’t understand why picking one or the other audio amplifier type should make a difference in the unamplified output coming from the mini jack. Is this the expected behavior? Or is there a defect in my particular unit?
12 June 2020 at 10 h 05 min #47476
ParticipantHi Pinbill
To be honest I think that yesterday was the first time that I have used the mini jack audio on the V1.5
I have used A Bluetooth transmitter & speaker on V1.3 &V1.4 with out any issues, so yesterday I plugged the same transmitter into the V1.5 and paired it to my BT speaker when I powered the wallbox & V1.5 I got a loud humming /buzzing from the BT speaker that varied in volume when the on board volume pot was adjusted, when I selected a song it played fine with plenty of volume from the speaker, strangely when I connect a pair of earphones to the mini jack there is no buzzing/ humming.
My dips are set as follows
1 off 2 on 3 off
what is IEMs ?
So in conclusion it seems to me that we both have a problem albeit different ones.
12 June 2020 at 17 h 03 min #47477
pinbill
That’s very interesting. I have been having intermittent Bluetooth hum issues when no music plays as well, but I haven’t spent enough time testing to isolate the issue. Will do so and report back any findings.
As far as the volume issue is concerned, can you let me know whether you get audio output from the mini jack when dip 3 is set to “on”? That was the configuration that was giving me a problem.
By the way, “iem” is in-ear monitor, a fancy term for high end earbuds!
13 June 2020 at 16 h 56 min #47480
ParticipantOk so I have just tested the V1.5 with switch 3 in the on position, so with my earphones plugged in I can hear the music but I think it’s not as loud as with dip 3 in off position, I also noticed another strange thing this afternoon my earphones have a volume control part way along the cable, when I adjust this earphone volume it also adjusts the volume from the speakers.
Also when I remove the earphone plug the speaker volume increases considerably.
14 June 2020 at 6 h 27 min #47481
pinbill
ParticipantHey Scudie,
Well, I went to test my v1.5 again today and now I get the no/exceedingly low (barely audible) output from the minijack irrespective of how any of the dips are set. Previously toggling dip 3 to off triggered reasonable sound output from the mini jack, but now nothing. Seems pretty clear that I have a defective unit.
The odd behavior of your speaker outputs, depending on the minijack connection, is pretty odd too — unfortunately I don’t have any non-powered speakers on hand to see if my unit exhibits similar behavior.
Seems like the v1.5 units may have some kinks that need to be worked out — or maybe we both just happen to have units with particular (though maybe different) problems. Hopefully someone on the sales/manufacturing side can chime in on this?
15 June 2020 at 10 h 37 min #47484
ParticipantGood Morning Pinbill
From what I have read on your posts I would tend to agree with you about your V1.5 being at fault. I think you would be better off sending the team an Email rather than waiting for one of them to visit the forum and read these posts.
I think in previous instances where a unit appeared to be at fault, a replacement unit was sent out fairly promptly.
15 June 2020 at 16 h 36 min #47485
pinbill
ParticipantYup, Gaelle and I have already been in contact and he is planning to send me a replacement. Thanks for your help!
2 September 2020 at 18 h 27 min #47726
artsound
ParticipantI received my 1.5 yesterday 9/1/2020….and immediately noticed something not right,i am using both speaker outs and a line out….2 problems,it doesn`t matter which dip setting i use,…off ,on on,….or off,off,off…..or off on,off……neither does the external olume control has any effect….and i hear a pop noise every time a song turns on….. i do not hear the pop noise on speaker out….but i do hear it on line out…..pop before a song starts….
external volume control does not work….tried different settings…
