- This topic has 26 replies, 4 voices, and was last updated 5 years, 2 months ago by
4 July 2019 at 0 h 29 min #46399
ParticipantI wound up with two emulators with defective audio amps so I decided to order a couple of mini amplifiers to see if I get them working. They’re PAM8403 chips direct from China, just like the ones they came with. I took the headphone out into the amp and they sound just like the others now. I had to break the traces on the PCB going to the speaker lugs but otherwise it was pretty simple. The pre-amp output seems a little high to me. Great for headphones but a bit high as a line out.
Now to find two more jukeboxes to go with them…
4 July 2019 at 22 h 09 min #46426
ParticipantHi Sooner
I remember Andy saying something similar to that about the pre amp & lineout.
Do you still get the background hum when using these amps?
So now you have them working what wallbox are you going to do next ? Anything in mind?
Am guessing you should have plenty to choose from over there. I keep looking at Rockola’s as so far I have not had one but they demand some high prices over here, so may have to stick with the Seeburgs.
This reply was modified 5 years, 9 months ago by
5 July 2019 at 18 h 45 min #46430
ParticipantThe background hum in all of mine isn’t too bad. Hardly noticeable unless the volume is very low. I haven’t really compared to see if it’s any different with the new amplifier.
What I notice on all units is that the tone changes significantly with volume level. As volumes is reduced from max the high frequencies are noticeably reduced around 80% and below. It’s also kind of odd that the line out varies with the volume control. Make me think the circuit was adapted from a design intended as a headphone out.
I saw on the facebook group someone had done one in a Coke theme. It looked pretty nice so I’m thinking about that if I can find one with poor chrome for a good price that I wouldn’t feel bad about painting.
5 July 2019 at 19 h 21 min #46431
KeymasterI guess too it’s for a headphone out. Sound is good with a headphone.
Also noticed that volume tone and level change if you adjust both volume knob.
If you use external volume control, integrated volume knob still vary volume, kinda strange.
29 July 2019 at 7 h 08 min #46538
ParticipantI saw on another post where Michiel mentions he has buzzing in his left channel speaker but not through the headphones. If that the case then it sounds like the left channel buzzing problem is in the power amplifier stage? If so you might be able to cure that by making this mod to your units too.
It take a long time directly from China but the amplifier is cheap!
29 July 2019 at 23 h 02 min #46541
ParticipantI ordered some of those amps this morning, when they get here I will try one on the emulator that Fabien had modified, see if I get anywhere.
cheers Scudie
1 August 2019 at 22 h 46 min #46550
KeymasterI’m not sure it’s the proper solution, because level is for a headphone output, it’s not a line out.
To make sure amp is the problem, you should connect new one on input before original amp.
1 August 2019 at 23 h 09 min #46551
ParticipantKlaatu – I know a line out should be feeding the PAM8403 on the unmodified emulators but I think the headphone out is what’s actually feeding it. The max volume is the same on my modified emulator as it is on my other emulators that weren’t defective. I wouldn’t expect that if a much lower line out signal was feeding one of them. Also, I haven’t studied the PC board closely enough to figure out what the circuit looks like but the volume pot output appears to go directly to the headphone output. Bottom line is that the modified amp sounds identical to the others but without the buzzing.
1 August 2019 at 23 h 26 min #46552
KeymasterAlright, after-all some use amp powered speaker to headphone output.
Would be interesting to have Fabien’s view on it.
Well done Sooner !
2 August 2019 at 1 h 54 min #46556
KeymasterNow, you can test other amp.
There is surely something better available from China. Maybe not compact enough…
2 August 2019 at 2 h 04 min #46557
ParticipantSomething else I notice. The volume control on the emulator cuts the high frequencies when the loudness is reduced below about 80%. The volume control on the external amplifier doesn’t do that. On my SC boxes I’ve been keeping the volume at about 60% and using the built in buttons to control the volumes. With the external amp I can keep the emulator volume at 100% and adjust the external amp volume to 60% and I don’t get the cut in high frequencies. In that respect it actually sounds a little better to me.
2 August 2019 at 2 h 06 min #46558
ParticipantI’m sure there are better amps available if you have room to fit them in.
The PAM8403 amps actually sound pretty good to me with better speakers. I hooked one up to directly to my hifi stereo speakers and was impressed with the volume. The sound quality was similar to what it sounds like when I use a Bluetooth transmitter connected to the headphone output.
2 August 2019 at 20 h 08 min #46563
ParticipantBeen in touch with Andy today thankfully the spare modified emulator that Fabien sent for me to evaluate has not been damaged while being tested. So when I receive the amps I will give it a go.
3 August 2019 at 1 h 05 min #46564
KeymasterOn PAM8403, Pin 7 is Left IN, Pin 10 is Right IN.
Why not try to plug your amp on these pin and remove old PAM8403.
3 August 2019 at 5 h 11 min #46565
ParticipantKlaatu – Because I think the buzzing noise is in the signals at Pins 7 & 8 and it works fine as is.
Scudie – Keep in mind if you want to use the existing speaker lug terminals you’ll need to cut the PC board traces that go to it.
3 August 2019 at 14 h 22 min #46566
KeymasterI tried to follow visually signal path on board, not easy.
I haven’t manage to determine if jack output is connected to PAM8403 or not…
But there is a lot of components connected just before jack output.That’s why I’m trying to find a pin to avoid modification of the signal through components.
4 August 2019 at 10 h 09 min #46575
ParticipantHi Klaatu
I have emailed you some diagrams, I thought they may help you follow the circuit.
4 August 2019 at 14 h 43 min #46578
KeymasterGreat !
5 August 2019 at 23 h 23 min #46582
Did you get the information? Was it of any help to you?
3 September 2019 at 22 h 11 min #46603
ParticipantThe amps that I ordered arrived today, took them a while to arrive from China around 35 days. Will post the outcome of the modification once I have had time to try them out.
Been busy doing other things at the moment.
Cheers Scudie.
4 September 2019 at 17 h 54 min #46605
Michiel
Great to keep us posted. With your help, maybe we can finally get rid of that hum…
Groet,
Michiel
6 September 2019 at 22 h 23 min #46607
ParticipantHi Michiel
Personaly I believe that Sooner deserves most of the credit for this, with some input from Klaatu also.
We do not appear to have had any input on the matter from the team!
I am busy with work, parents & other projects at the moment so it may take me few weeks to give it a go.
4 January 2020 at 19 h 37 min #46828
ParticipantOk so the Buzzing on the left speaker is GONE!!!
I have found time this week to have a go at the amp and emulator.
After removing the speaker / audio connector block as advised by Sooner, I cut the traces that lead from under the audio connector block to four of the connections of the on board amp, according to Klaatu’s post of the amp they are 1-3 & 14-16.
I ordered some of the PAM 8403 amps back in September of last year, but have since been busy with other projects. Finally this week I found the time and parts to have a go at replacing the onboard amp with one of the new ones.
Got it wired up this afternoon, the good news is that if there is any buzzing at all it is so very slight that I can’t audibly detect it through the left speaker now, it is a total transformation to how it was beforehand.
I may be being over critical as I am paying particular attention to the sound, trying very hard to listen for anything that should not be there.
As you can see in the photo it’s only a trial at the moment connected to the SC1 that I fitted the LED’s to, that are still going strong.
Have been sat listening to it now for an hour or more now and I believe all selections so far have been buzz free. I am convinced that it’s cured it. Very Happy & well worth the effort! Thanks to Sooner & Klaatu for the information in previous posts.Cheers Scudie
This reply was modified 5 years, 3 months ago by
Scudie. Reason: punctuation
6 January 2020 at 19 h 24 min #46840
ParticipantAnother thing I learned since I originally posted is that hot glue doesn’t stick to the PCB very well. I had to re-glue mine using epoxy.
6 January 2020 at 21 h 00 min #46841
ParticipantI was thinking of mounting the new remote amp separate to the emulator, with an hole in the backplate so if desired the volume could be adjusted using a small screwdriver without having to remove the cover.
Cheers Scudie.
9 January 2020 at 18 h 52 min #46888
KeymasterScudie, did you manage to find a trouble free solution for LED lightning ?
Not too bright ?
9 January 2020 at 21 h 41 min #46891
I think that the photo makes the led’s look brighter than they really are, just look at the ones on the emulator, the ones in the photo are the cool white colour, I have not tried them with a cover on yet to check what they look like, if they are too bright I will fit some higher rated resistors. These have been on now for weeks & weeks.
