Home › Forums › Wallbox2mp3 installation › Error lamp flashing.
- This topic has 6 replies, 3 voices, and was last updated 6 years, 11 months ago by
15 February 2019 at 12 h 53 min #44231
irus18352
ParticipantI’ve fitted a Wallbox to mp3 unit to my Seeburg SC1. It was working perfectly but now the error lamp is blinking twice repeatedly. Anyone hot any ideas?
Thanks, Ian.
16 February 2019 at 23 h 24 min #44336
ParticipantHi Ian just read your post concerning the error light. Found this in the support section which I have copied and pasted below.
Here is how to interpret this signal: – 2 flashes loop: The wallbox2mp3 fails to initialize the SD card; Make sure you insert a Secure Digital card in the slot provided for this purpose; If so, then remove and reinsert it. The wallbox2mp3 is compatible with most SD cards, regardless of memory size, brand, etc … It can happen in very rare cases that an sd card may be incompatible with our system; it would be a card that does not accept connections Serial Protocol Interface (SPI). If the problem persists, try to transfer the data to another SD card.
Fairly sure I read somewhere to always turn off the power before removing or inserting an Sd. I think if it was me I would try the removing and reinserting your original sd card if this has no effect I would do another sd card and try that.
Good luck.
17 February 2019 at 20 h 24 min #44445
irus18352
ParticipantThanks for that Scudie. I’ve replaced the SD card, removed it, replaced it, removed it, replaced it… error lamp still flashing.
17 February 2019 at 21 h 29 min #44448
KeymasterThe news SD card is formatted in FAT32 ?
18 February 2019 at 10 h 04 min #44504
irus18352
ParticipantI don’t know, I let the software format and build it.
19 February 2019 at 13 h 08 min #44661
KeymasterTry in FAT 32, Fabien may confirm…
I remember having trouble with one in NTFS.
19 February 2019 at 14 h 52 min #44665
ParticipantI have only ever used the software provided to format and build playlist on the SD card.
If irus18352 system initially worked with an SD card done using the software & if subsequent sd cards have been done in the same way but are not recognised by his wb2mp3 card, providing he has no bad connections with his wiring & his power supply 5v dc is providing adequate power to the board, I would think that it could be his wb2mp3 card that is at fault. Perhaps Fabien could suggest a way of diagnosing this ?
This reply was modified 6 years, 11 months ago by
Scudie. Reason: spelling error
