D I Y Drive in Speakers
Home Forums Your work D I Y Drive in Speakers
Viewing 11 reply threads
    • #46226
      Recently acquired a couple of car stereo speakers, by the look of them I would assume that they are from the late 70’s possibly early 80’s. I am guessing that they were meant to be fitted as accessory speakers to the rear parcel shelf of a car, that probably didn’t have either a radio or speakers.
      Any way as they appear to be made of aluminium, an idea popped into my head, after seeing Sooners post’s of his Drive in speakers  I thought strip the speakers strip the paint and polish them up. I have a length of stainless tube from an old patio heater  that will do as a post, so all I have to do is find something to go on top of the tube to form a housing / lamp some how connect all the parts together hey presto diy drive in speaker set.
      Busy doing other things at the moment but it’s a definitely maybe one day.Cheers Scudie
    • #46243
      Aluminum will polish nicely. Not sure about the grills. You may need to paint them.
    • #46499
      Have stripped one of the speakers, & started to remove the paint. Paint stripper had no affect nor did brake fluid, so ended up sanding it off.
      was thinking of having a go at making some replacement speaker grills from sheet aluminium & cutting slots in it. ?
    • #46500
      Or drill holes in it?
    • #46501
      Slots, but make a nice design, not only straight slots of same length.
    • #46504
      Will give the design some thought may be a deco inspired design.
    • #46587
      Have had a little time to look at those speaker units, decided to make a replacement for the mesh, so far I have cut a couple of pieces of 8mm aluminium to match the shape of the speaker body.
      Will now give the design of the speaker grill some thought.
      Cheers  Scudie
    • #46912
      Well under the black paint finish they are aluminium, I am guessing they were cast & as they were deigned to have a painted finish it hadn’t mattered that the aluminium was quite rough, so getting any kind of shine on them involved quite a bit of polishing.
      Any way one is nearly there now just the awkward parts around the screw holes to have another go at.
      Do the the repacement grills go? Any suggestions?
      Cheers
    • #46913
      Looks great! How did you cut the slots? They look perfect. Are you going to polish the front to match the rest?
    • #46914
      Machined the grills on a milling machine.
      Will try polishing the new grills not sure if they clean up the same as it was aluminium plate not cast.  StI’ll got to find something to go on top of the post to house a Bluetooth receiver/ amp. Looking for a round dome lamp with a chrome / stainless steel base.
      • This reply was modified 5 years, 9 months ago by Scudie.
    • #46916
      Aluminum plate will polish up nicely.  Same as cast.
    • #46919
      Inactive
      looks great !
