Which Power cord ?
Home Forums General discussions Which Power cord ?
Viewing 5 reply threads
  • Author
    Posts
    • #46843
      jwd1115
      Participant
      Probably a real stupid question but for a seeburg 3w1, what voltage and amp power cord do you prescribe to connect to the terminals/transformer?
      • This topic was modified 4 years, 10 months ago by Klaatu.
    • #46844
      Sooner
      Participant
      I use a standard lamp cord: https://www.ebay.com/p/7008911664?iid=163681903193
      I also put a 1 amp fuse in front of the transformer (although 1/2 amp would probably be better).
    • #46846
      Participant
      I use 3 core 1.5 mm2 round flex, with a 3amp fuse in the three pin plug and the earth wire connected to the wallbox chassis.
      I fit an automotive 3amp blade fuse on the output of the transformer.
    • #46847
      thatsmesd
      Participant
      I thought the 24v “Com” was connected to the chassis?
    • #46848
      Sooner
      Participant
      Yes the chassis is connected to the 24V “common”.  Interesting to know the chassis can also be grounded.  I may need to retro-fit some of mine to be safe.
    • #46849
      Participant
      I also use the the chassis as a ground for 5v dc  for LED in the  illumination of the pages.
  • You must be logged in to reply to this topic.
