Home › Forums › Wallbox2mp3 installation › Weak link : fuse questions.
- This topic has 23 replies, 3 voices, and was last updated 5 years, 9 months ago by
Scudie.
14 June 2019 at 20 h 59 min #46291
ParticipantHi just a word of warning to any one that is working on or restoring / converting a wall box, or for that matter someone who may be contemplating doing so.
The wallbox requires a 25VAC power source to allow it to operate. I have worked on / repaired, converted a dozen or so Wallboxes now, and have always always always fitted a 2 or 3 amp fuse between the 25volt output wire of the transformer & the terminal block marked 25vac or live, inside the wall box, with a fuse in place it will protect your transformer, if you should accidentally cause a short to common / ground.
I seam to remember my Father telling me that Familiarity breeds Contempt, well Familiarity or forgetfulness has just cost me the price of a new transformer.
Dont forget to fit a Fuse they are much cheaper than transformers!
This topic was modified 5 years, 9 months ago by
Scudie.
15 June 2019 at 9 h 06 min #46293
Sooner
ParticipantI’ve been putting a fuse in front of the transformer just because that’s the way all other electrical devices I’ve seen are set up. Any reason why you put yours behind the transformer?
15 June 2019 at 9 h 55 min #46296
ParticipantI have also been replacing the standard 13 amp fuse in the the 3 pin uk plug with a 3amp.
As to in front or behind the transformer I thought that if the fuse was placed in the circuit between the power source and the item it is powering ie motor, lamps etc that this would be the correct place for it.
I believe that in the two descriptions of how to integrate the emulator into wallbox’s on this site they placed the fuse inbetwee the two windings of the terroidal transformer.
I am not an electrician and will stand corrected if I am doing it wrong.Cheers Scudie
20 June 2019 at 0 h 13 min #46352
ParticipantJust as a trial I have just tried my system with a 1 amp fuse inserted, which as expected blew as soon as a selection had been made.
Hopefully the 3 amp fuse in the 25vac circuit should be low enough to protect the system from any further problems.
And the 3 amp in the wall plug to protect any one using it.
20 June 2019 at 1 h 40 min #46353
Sooner
ParticipantI forget about you folks in the UK having a fuse in your power cords. Here in the US there’s always a fuse first thing inside all electrical devices. My thinking on where to put the 3 amp fuse is that if there’s a surge or overload on the output side of the transformer there will also be a similar surge on the input side. My thinking is that because the transformer isn’t 100 efficient the current on the input side is always a little higher than it is on the output side. So putting the 3 amp fuse before the transformer should protect it as well as protect someone touching the wallbox if there was a short occurring before the transformer. Killing two birds with one stone sort of. I saw where they put it in the instructions but I’m not convinced that’s the right place for it if there’s only one fuse. I probably should research my theory a little though just to be safe.
What happened that cause your transformer to blow?
20 June 2019 at 8 h 24 min #46354
ParticipantI was fitting & testing out a credit switch while it was live to see how many credits it would register, and momentarily pressed the switch by mistake while one wire was touching ground & that was it game over. Went to change the fuse and realised my error. The 3amp in the plug was fine.
20 June 2019 at 18 h 07 min #46356
Sooner
ParticipantHmm… So my theory may be all wrong. Good to know.
21 June 2019 at 4 h 23 min #46357
Sooner
ParticipantOkay… I think I just figured out the error in my theory. If the backside of the transformer is 24V and 3 amps, that’s 72 watts. Assuming 100% efficiency the front side at 120V and 72 watts would be just 0.6 amps. Conversely, for the front side to be pulling 3 amps at 120V (1800watts), the back side would have to be pulling 15 amps. Not good for a transformer rated at 3 amps.
21 June 2019 at 8 h 27 min #46358
ParticipantThat sounds to me that at you might be considering fitting a second fuse after the transformer?
I use one of the blade type automotive fuses, pushed into a couple of insulated female spade connectors.
22 June 2019 at 3 h 37 min #46360
Sooner
ParticipantI think I’ll look for a 0.5 amp to put in front instead of the 3 amp and see how it works. I that blows I’ll increase to 1 amp. (unless I can find a o.75 amp).
22 June 2019 at 8 h 53 min #46361
22 June 2019 at 12 h 27 min #46363
Sooner
ParticipantWas your 1 amp fuse in front of the transformer? I was talking with someone else and they were using a 1 amp fuse in front with no problem.
22 June 2019 at 18 h 43 min #46364
25 June 2019 at 8 h 04 min #46367
Sooner
ParticipantYes, I would expect a 1 amp after the transformer to blow.
8 July 2019 at 20 h 32 min #46484
Klaatu
KeymasterI only use 1 Amp fuse before transformer.
8 July 2019 at 22 h 59 min #46485
ParticipantI guess in France you have a two pin plug ? Does the plug have a fuse inside it ?
Here in the UK we have 3 pin plugs connected to a 3 core flex, live, neutral & earth for 240v AC 13 amp mains.
I fit a 3amp ceramic fuse to the plug and conect the metal body of the wallbox to earth wire. To protect anyone touching the metal casing, should there be a short.
I fit a 3amp auto motive blade type fuse on the 24vac wire from the transformer to the wallbox this protects the transformer from me when I make a mistake while testing or fault finding.
I could buy 1 amp ceramic fuses, but I get the 3amp ones free.
8 July 2019 at 23 h 36 min #46491
Klaatu
KeymasterIn France we have 2 or 3 pins but no fuse inside plug.
8 July 2019 at 23 h 42 min #46492
ParticipantWhich do you use on your wallbox conversions?
9 July 2019 at 21 h 13 min #46493
Klaatu
KeymasterBoth
9 July 2019 at 21 h 19 min #46494
ParticipantSo is the French 3 pin like ours? With a live , neutral , & earth?
9 July 2019 at 21 h 20 min #46495
Klaatu
Keymasteryes
9 July 2019 at 21 h 24 min #46496
ParticipantSo if you use a two pin plug on some conversions, does this have an earth?
9 July 2019 at 21 h 33 min #46497
Klaatu
KeymasterNo, and my apartment isn’t earthed for electricity.
10 July 2019 at 20 h 40 min #46498
ParticipantI had a bit of a read up on French mains electric, (just curious) from what I read France and most of Europe use the same type of plugs & sockets, the earth connection being part of the socket and does not necessarily rely on a pin like uk plugs.
Also sockets are not switched where as most in the uk are, and plugs are not fused. Aparently the way we wire our houses is also different!
